cpt-pat avatar image
cpt-pat asked
Disabling Cerbo WiFi
I am considering deploying the Cerbo GX product, but I absolutely cannot have it running WiFi on the 2.4 GHz band as it will interfere with the very weak access point at my harbor. I know - I've tried this. I can't even have the Cerbo transmitting in "client" mode on 2.4 GHz. I need to either disable the Cerbo WiFi from transmitting entirely on 2.4 GHz and use ethernet connectivity to my router (preferred solution), or use the Cerbo Wifi on the 5 GHz band.
Reading the manual, it appears I can not do either. Am I correct?
cerbo gxwifi
wkirby avatar image
wkirby answered ·
You can choose not to connect to any existing WiFi networks.
You can choose to switch off access point mode.
You can switch off Bluetooth too if that's also an issue on 2.4GHz.
