palom170 avatar image
palom170 asked
ESS Fronius Ac-In, doubt about shore current limit
energy-meters-et112-2019-01-21.pngHello victron community members, I have a doubt about AC in grid limit
Currently in Spain, with the electricity tariff change we can hire 2 powers, so we can configure the ac in limitation of the victron depending on the schedule, I have a fronius in ac in and yesterday I did a test, by limiting the ac in input of the victron at 6A, once it reached that consumption in loads in ac out 1 it no longer generated more, it started to take power from batteries, is it fine? Is it not able to detect that this energy comes from the inverter? and not from the públic grid.
Thanks in advance.
ESSAC PV CouplingFronius
Alexandra avatar image
Alexandra answered ·
@palom170@gmail.com
That is correct. With your 6A limit at 230V your loads up to 1380W will pull from your grid and then anything higher will be used from the battery.
It will obey that limit you have set as much as possible at all times.
palom170 avatar image palom170 commented ·
Thank you for your answer, what I didn't expect it limited the inverter in the ac in.
Alexandra avatar image Alexandra ♦ palom170 commented ·
Is there a reason why you are limiting the input current in on the multi?
palom170 avatar image palom170 Alexandra ♦ commented ·
For avoiding the main fuse blown .
