alexgill180 avatar image
alexgill180 asked
Blue Smart IP22 repeated 30amp then 0amps?
My IP22 Blue Smart charger is not working properly. It charges in bulk mode at 30amps for around 30secs, then the amps drop to 0 and it switches to absorption for around 30secs. This cycle keeps repeating.
I have tried using a replacement charger and the same thing happened. It has been working fine for around a month but has only recently started doing this.
Any ideas? Thanks
MultiPlus Quattro Inverter Chargerchargerip22
Murray van Graan avatar image Murray van Graan commented ·
Can you share some more info, what battery are you using, cable size between charger and battery and also the length of this cable. It sounds like a large voltage drop between charger and battery could be the cause
MultiPlus Product page Quattro Product page
MultiPlus 230V ManualQuattro 230V Manual
MultiPlus 230V Datasheet Quattro 230V Datasheet
VE.Bus Error codesVE.Bus configuration guide
Chargers.
