miki35 avatar image
miki35 asked
Blue Smart charher IP65 12V/25a profiles
Hi, which profile I need to use for charging Victron AGM Deep Cycle battery 12-110.
I have doubts between regular modes -normal or high and those predefined presets in Victron connect app for AGM Gel deep cycle batteries (1) and (2).
There is no predefined preset for my battery.
Tks in advance.
chargerAGM Battery
Paul B avatar image
Paul B answered ·
Then set user defined and then set the voltages to suit your battery
miki35 avatar image
miki35 answered ·
I hoped that some one will give me that profile.
I am aware of user defined option, but I was looking for already tested profile for Victron AGM Deep Cycle battery 12-110.
Alexandra avatar image
Alexandra answered ·
@miki35
https://www.victronenergy.com/upload/documents/Datasheet-GEL-and-AGM-Batteries-EN.pdf
From this datasheet comparing the two profiles either one will do. There is really only one difference in the preset that I saw, it is on the absorption voltage and both are within the specifications of the battery manufacturer.
@miki35
If you look on the side of the battery you can also check the charging details As long as you are not exceeding the charging amps and operating temperatures as well as recommended discharge depth, you should be fine.
