Jono (Victron Energy Staff) avatar image
Jono (Victron Energy Staff) asked
Victron Wiring Example - Catamaran Lithium Setup with 2 extra alternators
This drawing is for 24 Volt with a Quattro 5KW 230VAC 24VDC, 600Ah Li batteries, a Lynx Smart BMS & multiple distributors, two smart battery protects, a Cerbo with GX touch, a generator, two MPPT’s and two Extra Alternator with Wakespeed WS500 regulators.
The two regulators work in tandem mode and are CAN Bus connected. This will prevent the so-called hunting effect about who is leading the charging process.
Here is a link to the full-sized pdf.
Lithium BatteryVE.Canwiring diagramyacht
hoeken avatar image
hoeken answered ·
I'm having a new semi-custom catamaran built and we're doing an all-victron system. Is it possible to commission a proper drawing like this for it that is specific to our setup? Basically this + tons of solar + dual Integrels + 48v to 24v w/ buffer battery + hydro generator.
Battery Compatibility
