clnewman5566 avatar image
clnewman5566 asked
Are my BMS and Solar Charger working properly?
I have the Smartshunt networked with an MPPT 150/70 charger. There are three 325W solar panels, and four UT1300 105ah lithium batteries.
I'm not sure the charging system is working properly. Please see the photos. Is what I'm seeing normal ? Why isn't the BMS showing a positive rate of charge?
The battery load looks about right (10.77A), but shouldn't I be able to see a net increase in SoC? Are my Victron devices configured incorrectly? When I charge from my generator, the BMS shows it's charging.
We're full time RVers, and it's imperative I get this right. TIA
Edit: I don't know why the charge controller Screenshot isn't showing, but there's a link for it.screenshot-20210603-094438.jpg
MPPT SmartSolarSmartShunt
As always check your wiring of the SmartShunt.
I guess the MPPT negative is connected to directly to the battery instead of the "load/charger" side of the shunt.
clnewman5566 avatar image clnewman5566 commented ·
You may be on to something there. I installed the Shunt myself, but the RV dealer installed the MPPT. I followed the Shunt instructions to a T, but didn't bother to check the MPPT.
Would simply moving the MPPT negative to the load side of the Shunt probably solve the problem?
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
