msmolow avatar image
msmolow asked
LBCO Time Delay Setting
It appears my Multiplus 3000 inverter is disabled immediately upon reaching the Low Battery Cut-Off setpoint, which does not account for the voltage lag when I turn on my toaster oven.
Xantrex inverters allow you to set the time delay and Magnum inverters have a one minute time delay.
I can't find an equivalent Victron setting.
Am I just not seeing it? If there is no time delay, is there a reason Victron does not have one?
low battery warning
No, there is no such setting.
But if you connect everything to AC OUT 2 instead of AC OUT 1 you could set the low-voltage cut-off a bit lower (10V or 9V) and then use an assistant to switch off AC OUT 2 with a delay.
msmolow answered ·
Matthias, why the complicated work around? Is there a reason Victron chose not to include a simple setting that two respected competitors have?
