Serge avatar image
Serge asked
Trigger CERBO GX relay based on CAN bus data from REC Q BMS
Newbie warning. )) I would like to be able to control CERBO GX relays based on temp reading from REC Q BMS. My REC Q BMS is on the CAN.Bms bus and it seems like the CERBO can access all(?) data that REC publishes. I would like to turn on a fan that would cool REC BMS during balancing so it does not reach 55C. It seems like the REC BMS publishes its internal temp on CAN bus. Where do I start? Thank you!
cerbo gxBMS
