digitaldvd avatar image
digitaldvd asked
Victron charger settings etc via the vrm portal are you able to change these via the portal
Hi all
am i doing something wrong if i use victron direct to my pc with mppt 100/20 connected
i am able to change voltage setting etc with out any issues, when i use my smartphone
using blue tooth i am able to connect to the charger and go to settings and change voltage etc
without any issue.
But when i use the online vrm portal using my rasspberry pi i connect to the portal ok
and i can see my mppt 100/20 ok and i assumed that from the portal i would be also able to change settings
voltages etc but cannot see any setting to do this.
Am i missing something or in fact you cannot change the voltage setting etc via the portal.
Thanks
VE.Direct
digitaldvd avatar image digitaldvd commented ·
Thanks for the reply now i see where i was going wrong i was not waiting long enough
for the download information via the cloud,seems our broadband is a bit slow .
problem solved, Thanks
trip-tracks avatar image
trip-tracks answered ·
