znep avatar image
znep asked
NMEA2000 GPS
Hi folks,
I read in the v2.6 release notes that:
the ability to read GPS (location, height, speed) from the N2K network has been added.
I can't get this working with my CCGX running v2.66. It can see the other devices on my n2k network. I unplugged my USB GPS and rebooted.
Any tips on where to look or if there are any configuration options that need to be set? I couldn't find any.
Thanks,
Marc
NMEA 2000 - N2Kgps
Paul B avatar image
Paul B answered ·
is the USB GPS a nmea0183 device, as most of these type of units are.
if it is then you will need a nmea0183 to nmea2000 converter at a Min and even then it may not work
Also adding a USB device to a GX device does not mean that it will connect you need drivers and the drivers in the GX device may not suit the unit you have.
znep avatar image znep commented ·
Hi Paul,
Thanks for the response. I wasn't as clear as I should have been in my post. The USB GPS works fine, I just don't want to use it if I don't need to. I have a Vesper Cortex on my n2k network that outputs GPS information that I would like to use instead.
