Dosheimer avatar image
Dosheimer asked
Smart BMS 12/200 no charge algorithm
Hi!
In the manual of the very interesting Smart BMS 12-200 I can see that "no charge algorithm can be applied internally". In all Victron system overviews I only can see that always this BMS directly is connected with the LFP battery.
On the other hand I have a MPPT 100/50 also in my system, directly connected with the LFP batteries and configured to LiFePo4 charging algo.
Therefore my uncertainty is about the missing LiFePo4 charging algorithm at the Smart BMS 12-200 charging side. Is there anything bad about that or does this reduce the life expectation of the FBA in general or something else?
Your response is much appreciated, thanks upfront!
BMS
Dosheimer avatar image Dosheimer commented ·
...I could imagine that the left alternator plug works like a Cyrix Li ct in terms of max. voltage protection, but I cannot find any information on that issue.
