chezgals avatar image
chezgals asked
BMS 12/200 as current limiter with alternator control cable (ASS 030510100)
I want to use this as a voltage regulator for my alternator but I'm using a none victron bms. I've seen on another post that the red cable is a 12v constant on. What voltage will I need to put onto the yellow wire to activate the cut off circuit. I think it's voltage on for switch on and voltage off for switch off. Just how many volts does this yellow wire need?
BMSVE.Bus
What is VE.Bus?
