paul-2 avatar image
paul-2 asked
Victonconnect breaking VEConfigure 3?
It appears that after I connect to a device with Victronconnect, I can no longer reach it using VEConfigure. I just bench tested with a multi and it worked fine with VEConfigure 3, then I connected to it with Victronconnect and now when I tried with VEConfigure or VE.Bus System Configure, I just get the endless dots, then the 'help with connections' message. But I can't reach the multiplus anymore.
VictronConnectVEConfigure 3
Is VictronConnect still running in background?
Com-port connections can only be used from one program at the time.
If VictronConnect still running in background it blocks the connection for VE.config.
darden430 avatar image
darden430 answered ·
VEConfigure is used to configure our Chargers as well as Inverter/chargers Use todays normal version, VEConfigure 3, for all newer versions. If all those do not work; the MK3 may be broken, please contact your dealer.
prepaidcardstatus
paul-2 avatar image
paul-2 answered ·
Mk3 still works (I can use it for Victronconnect). VictronConnect has been completely shut down (I've rebooted in between tries).
It appears that once I connect to a Multi w/ VictronConnect that the unit will no longer accept a connection from VEconfigure. A new unit right next to it will accept VEconfigure connection.
paul-2 avatar image
paul-2 answered ·
I think the blocked com port was the problem. It is still requiring a reboot, but will allow me back in with ve.configure now.
