I am trying to connect my window 10 to a VE direct interface cable to a BlueSolar MPPT Charger. my computer doesn't see the cable. Do I need a driver?
Hi @Chipster, welcome to the Community!
Usually the necessary drivers will be installed when you install VictronConnect on your Windows 10 machine, but if that fails to occur you can download the driver package here.
48 People are following this question.
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Are 50vdc solar panels wasted on a 12vdc system?
Large difference between solar blanket voltage output and Victron dashboard
SmartSolar MPPT 75/10 not charging
Peak Power Pack 40Ah and SmartSolar charge controller - how to connect & setup
