Hello, I've found a nice diagram of a system including the LynxSmartBMS, CerboGX and MultiPlus-II. I'm wondering if such configuration also supports the old version of MultiPlus?
The diagram I'm referring to is here - https://www.victronenergy.com/upload/documents/MultiPlus-II-3KW-2x120VAC-12VDC-400Ah-Li-Lynx-Smart-BMS-Cerbo-GX-touch-generator-MPPT-Orion-Tr-Smarts.pdf
Hi @bezda,
I'm pretty sure there is no limitations as long as the MultiPlus has VE.Bus, so that it interconnects with the GX device and then get controlled by the Lynx Smart BMS.
What's the MultiPlus you have and what firmware version?
Hi, @Stefanie, I have the MultiPlus Conpact 24/1600/40, with firmware 469.
I'm mainly asking this question, because I have the VE.Bus BMS at the moment and that one needs direct connection to the MultiPlus, where LynxSmart connects via GX device.
It will work with your Compact 24/1600/40.
In my system it works w/o problems together with a MultiPlus 12/3000/120-50. And another good thing, you don't need the VE.Bus BMS assistant anymore.
26 People are following this question.
