I have only 16 inches of vertical space where I would have to install this unit. Would this unit fit if installed vertically and have space for ventilation and wire routing? Could the unit be install horizontally?
Hi @vieuxgeek, welcome to the Community!
Have a look at the manual; as noted in the technical specifications at the end, this unit will not fit in your described space.
These units may be installed in a horizontal orientation, though it should be noted that this will somewhat affect its cooling characteristics as well as negatively affect its moderate drip-resistance rating.
Thank you so much for your answer. I did see the info in the manual but was wondering if there was any option that could work. I will pass on using this product as I don't want it to be installed where cooling may be affected.
Hi again @vieuxgeek, don't let the cooling part scare you off - these units used forced-air cooling, so it will be able to keep itself cool! My statement was just pointing out that, since heat can no longer rise out the top vent when it's installed horizontally, the cooling will be less efficient, which means that the internal fan will be likely to run more frequently than if it was installed in an upright orientation.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
44 People are following this question.
