Glenn avatar image
Glenn asked
Parallel 2 Multi 3000's
I want to install 2 Multi 3000's (parallel) in my RV and the RV has 50A service with a 50A dual pole main breaker. My system is 12VDC. How can I feed AC to both multis? By that I mean if I put 1 - 30A breaker on each side of the 50A main,.. with split phase I'm inputting 240V (NO NO!). If I put 2 - 30A breakers both on the same side of the 50A I'm potentially overloading one side of the service. FYI, nothing in the RV runs off of 240V. I hope I've stated this correctly and hope there's an easy solution for the issue.
multiplus in parallel
seb71 avatar image
seb71 answered ·
6000VA on a 12V battery is not a good idea.
marekp avatar image marekp commented ·
Copper required for the battery connections will probably by as heavy as this RV, :)
