brianor avatar image
brianor asked
MultiPlus device missing from VRM Firmware screen
Hi, I have a MultiPlus II 48/5000 connected to a Cerbo GX. All devices reflect properly on the Device List of VRM Portal. However, when I select the firmware update option, it perform scan but only detects the SmartSolar MPPT controller.
The VRM setting on Cerbo is correct (two way communication enabled, stable internet connection through ethernet etc).
Any ideas?
VRM
What other devices do you have connected?
FW update for the MultiPlus is only possible if the Cerbo is at the latest FW (v2.66).
https://www.victronenergy.com/live/venus-os:remote_ve.bus_firmware_updates
brianor avatar image brianor commented ·
Got it - Cerbo firmware was on v2.63. Thanks.
If Cerbo is connected to Battery port of MultiPlus (sharing same connections as battery), will it lose power during firmware update? Especially if I disconnect the BMS cable on Cerbo to battery?
