I attempted to connect a 4/0 copper cable 5/16 hole lug from the Multiplus to the Distributor, but lug seems to be too large to fit into the opening for the negative bus bar on the Distributor. Can someone recommend a lug that will fit?
Thanks
Thanks
I used 4/0 lugs with 3/8" hole off Amazon, works fine.
Grinding the lug compromises the lug. Grinding out the plastic curve compromises strength of the plastic divider and possibly voids any warranty. I would like to know what the official Victron policy should be to accommodate 4/0 lugs. I have looked for a lot of different 4/0 lugs and none will fit without some form of modification.
Thank You
33 People are following this question.
