Greetings,
May i know whether it is possible to get data displayed in the ' Remote Console' of Venus GX through Modbus TCP coding to Programing board of Texas instruments (launchxl2-570lc43)
Regards,
Advaith
Greetings,
Regards,
Advaith
Hello Markus,
Thank you for your reply.
I actually want to have make a communication between Venus GX & Programming board (launchxl2-570lc43 )via LAN cable.
From that communication, I want to receive the data which is displayed in the Remote Console of Venus GX.(such as Battery voltage, current, ac loads etc...).
Thus the programmable board gets information about the devices connected to Venus GX and will be able to perform like a VCU(Vehicle Control Unit).
Before that i need to know whther the VGX will provide all information via LAN cable.
Regards
Advaith
yes! You can use (e.g.) ModbusTCP protocol to pull data from the VGX to your programming board.
See here:
GX Modbus-TCP Manual [Victron Energy]
and here:
Download file Modbus-TCP register list - Victron Energy
Have fun! ...and success!
Hi Markus
Can you please provide more information about Modbus TCP protocol
Thank you for the reply
Can you plaese shre more information about Modbus TCP coding that would be suitable for implementing communication with VGX
Regards
Advaith
This question is too general to give a good answer.
I don't know your programming board.
BR
The programming board is launchxl2-570lc43 from Texas instruments
The programming language used is embedded c
Is this information enough or do you want technical information
Regards
Advaith
You want me, to write your code?
Sorry - this is not going to happen.
But see here for examples: modbus tcp c# - YouTube
I didn't mean that. I actually need a proper guidance through this community
Regards
Advaith
Here is some guidance through this community: victron community guidelines
BR
37 People are following this question.
