for configuration and using of the "strompi" extension i need to install python-serial, python3-serial and minicom.
Somebody know how to install these packages?
Best regards
Mich
Best regards
Mich
I have the same problem but my current workaround is to configure the "strompi" on another Pi and then just swap it.
You can install python-serial with pip. Of cause first you have to install pip. For the minicom I failed to compile it on the Venus OS (the large version which includes the compiler) even after installing a lot of missing libaries. ./configure went through, but "make" stopped with an error.
You can run a precompied minicom from another Pi. I am currently struggling to get /dev/serial0 activated.
I now not much help, but may be you can find out to get the serial port online.
Cheers
Dirk
29 People are following this question.
