tobias-endress avatar image
tobias-endress asked
Safety Switch at Aux Input of an Quattro
Hello everyone,
My problem is that I have connected an emergency stop switch to the aux input of an Quattro. When this is pressed, the Quattro goes off. However, when the switch is unlocked, the Quattro restarts automatically. Is there any way to prevent the Quattro from restarting automatically?
Assistants
Alexandra avatar image
Alexandra answered ·
@Tobias-Endress
From a software side no. The assitant only switches off the output of the Inverter not the unit itself.
when you set up the assistant it tells you....
However in your safety procedure maybe include the front rocker to be switched off (if it is stand alone) before clearing the reason for and release of the emergency stop and then a full system restart.
