agnieta avatar image
agnieta asked
What is the right setting Low Battery shut down Muliplus 12V
The default inverter settings 'DC input low pre-alarm' and 'DC input low shut-down' from the Multiplus 12V/80/2000 are very low.
DC input low pre-alarm: 9,3V and DC input low shut-down: 10,9V.
What are the right settings for Victron super cylcle AGM accu's?
Assistants
Peter Polz avatar image
Peter Polz answered ·
This Setting is the very very last hard off setting. You never should reach such a setting and better control it with external BMV. Voltage Hardlimmt CUT offs are difficult and always depeding on batterie capacity / load current in the moment of switching off.
JohnC avatar image
JohnC answered ·
Hi Agnieta. This is something you'll need to determine yourself. Largely dependent on loads you might apply and how far your V dips. Even with full charge, a fair load will affect that, but may bounce straight back. So you don't want to trip for a peak load if your batts are fine.
Pete above is quite correct. Perhaps you could dodge the BMV if you 'get to know' your batts.
captrevere avatar image
captrevere answered ·
Agnieta,
We’re you satisfied with those answers?
Dan
