I have an old multiplus 12/800/35 with firmware 1903142VFD
There are 2 release trains available, xxxx1xxx and xxxx2xxx.
Should I update and if so, release train 1: 1903159.vff or release train 2: 1903209.vff ?
If your existing system is working well without any problems then no need to update.
If you are installing a new system, then it is a good idea update to the latest version.
If you need features from xxxx2yy (like some assistants) then change to that version.
If you do not need features from xxxx2yy the stay with xxxx1yy.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
46 People are following this question.
