hughc avatar image
hughc asked
Digital Multi Control lights flashing
I have a DigitalMulti Control GX Panel. This morning when I turned on the inverter the absorption and float lights started flashing on the panel. I'm on a mooring and not connected to shore power. The inverter appears to be working normally. What is causing the the absorption and float lights to flash on the charger side of the panel?
Thanks,
Hugh
Victron Toolkit App says temperature sensor error.
hughc avatar image hughc commented ·
Hmm, thanks for the response. After an hour or two the lights stopped flashing.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ hughc commented ·
Keep an eye on it, if it happens more often you maybe have to replace the sensor.
Part number is: ASS000001000
https://www.victronenergy.com/accessories/temperature-sensor-qua-pmp-venus-gx
