- Hello,
My dcm will not go lower on ac1 than 12 amps. In some harbours the shore power is just 6 amps.
How can i get the shore limit on the d lower than 12 amps?
There are lower limits, how much depends upon the model and what firmware it is on. You can find your model in the list below and check if a firmware upgrade will improve the lower limit for you.
Same question here, if 3 are in parallel you can’t set it lower than 10 amp shore power, correct? Can you set it lower if one would use the cerbo gx and enable override by remote in Multiplus settings?
5 People are following this question.
