paul-ainsworth avatar image
paul-ainsworth asked
Filax 2 Transfer Switch
Filax 2, When the priority souce is unpluged (shore support) yellow light, no red fault light on. we are then switched to the alternative source (Victron inverter) the yellow light glows on together with the Priority Source fault light (red), is this correct and working correctly or is there a genuine fault
virtual switch
VE Configure/Virtual Switch
Ignore AC input using the Generator Assistant
