During the voyage, the alternators charge my service batteries. This is also displayed fine on 'Advanced'. AC consumption is also seen on the 'Dashbord' but it does not appear in 'Historical data' (bar graph). Do I miss something? Thanks!
Hi Paul,
Thanks for your reply!!!
This can't be the reason because I am 24/7 online.
And I always have AC consumption (aprox. 100W minimum).
Example no AC: Between 10 and 12 AM.
It only occurs when sailing with the DC alternator in work.
Additional remark:
Also the Excel download shows no AC consumption during a trip with the DC alternator in work.
Not knowing the whole system, the yellow highlighted cells also correspond to a higher PV (solar panels) to battery. If the engine is running, then the alternator may well be being accounted for as the supply to the consumers, so the PV is not supplying them neither are the batteries.
Hi all, the documentation regarding the requirements for those bar graphs is here: https://www.victronenergy.com/live/vrm_portal:faq
How to change the Owner of a VRM installation
37 People are following this question.
