calebs avatar image
calebs asked
Inverter RS 48/6000 inaccurate history
The data for the past days is showing up incorrectly. The last two days it went through both float and absorption cycles but this is not reflected in the record. Instead all the previous days are wiped by default to bulk only. I am wondering if something is triggering this inaccuracy. I see a low battery voltage notification. This doesn’t make sense because the last 2 days for sure I did not run the battery below 49v. Has anyone else had a similarly puzzling inability to get an accurate history? Why might the low battery notification be triggered if the battery never actually was low?
low battery warning
