does the new GX Tank 140 work with the Venus OS on the Raspberry pi? I have Firmware 2.66 on a Raspberry pi 3+ and I cannot see anything that has to do with the GX Tank 140. It's connected via USB.
Well - here's the answer by myself:
I've installed release candidate 2.70-6 on a new SD-Card. It's not possible to update from 2.66 to 2.70!
After install and basic setup (WiFi) - GX Tank 140 plugged into USB port and baaaaam: All sensors available and analog inputs as well!
Great Work. Thank you.
Thanks
41 People are following this question.
