baard avatar image
baard asked
Victron multiplus 12/1200/50 Relay activation
Trying to get to use the multiplus relay to activate when AC is cut off, but cant seem to get it to work. It is set up like this:capture.png
When i measure between COM and NC/NO nothing happens when I disconnect AC power. What I am doing wrong?
Regards
Baard
MultiPlus Quattro Inverter ChargerAssistants
Do you also have a assistant to switch the relay to ON?
(You can't switch it OFF if it wasn't ON :) )
baard avatar image baard commented ·
That did the trick! Thank you very much! Quite logical, but did not think of it that way :-)
netrange avatar image
netrange answered ·
Die you send the changes to your System ?
