miya avatar image
miya asked
MultiPlus with a BMS CL 12-100 -- Load and Charge Disconnect Not Working
Hi All
Help please...
My Multiplus (EasyPlus Compact 12/1600/70) will not switch off when instructed to by the BMS (Smart BMS CL 12-100). My set up is as per below -
I am using the Cable for Smart BMS CL 12-100 to MultiPlus (PN: ASS070200100). I have tested the V output from the load and charge disconnect on the BMS - they are performing as expected (both normally high). But when the BMS changes to load or charge disconnect - the Multiplus stays on. The V on the cable becomes free floating, as expected, but makes no difference to the Multiplus.
I have connected the Cable as per instructions which states - "When used with the MultiPlus Compact 800VA-2kVA models connect the black wire to the middle terminal and the red wire to the right (IN) terminal."
From the Multiplus manual - I have plugged the cable in as per below - black to terminal 2 and red to terminal 3.
I am expecting the Multiplus to switch off when either load or charge disconnect become free floating - but the Multiplus stays on.
Any help / advice would be appreciated.
Thanks,
Tim
MultiPlus Quattro Inverter ChargerBMS
You also have to change the DIP switch settings, unfortunately this detail is missing in the BMS manual:
(MultiPlus Compact manual)
miya avatar image miya commented ·
Hi Matthias
Thank you so much for the advice - and the extract from the manual.
OK - I have set the DIP1 & DIP2 to OFF. I have saved the new setting by switching DIP8 on and off.
But - the Multi is now switching off and on repeatedly, It switches off for about 5 seconds and then comes back on for about 10 seconds, then back off, and keeps doing this.
The BMS cable is not plugged in to the BMS - so the V on the charge / load disconnect are both 0v. This should keep the Multi OFF at all times - I think,
Can you offer more advice ?
Thanks, Tim.
