John Berger avatar image
John Berger asked
Is it OK to simply change the default SOC bulk parameter setting (85%) in VEConfigure3 to a higher value, say 95% or even higher?
BMV Battery MonitorVEConfigure 3
Probably not. A lead battery is typically around 85% full by the time the system switches from bulk to absorption.
Elimac avatar image
Elimac answered ·
Allow me to ask here another question that might also be relevant... 85% or 95% of what capacity? In the same menu in VE configure where this is set, the battery capacity should be the C10, C100 or other value? If incorrectly filled, this will have also the same effect in wrong SOC values...
neoneddy avatar image
neoneddy answered ·
You can but you'll risk boiling off your electrolytes.
