smoothfroggy avatar image
smoothfroggy asked
VECan BMS+Skylla IP65 12/70 1+1 / Current control
Dear Community,
I would like to request your help regarding setup of a Skylla IP65 12/70 1+1 connected on VE.CAN to a intelligent BMS.
A REC-ABMS is issuing CVL, CCL and DCL data (respectively Charge Voltage Limit, Charge Current Limit and Discharge Current Limit). Data appears correctly on a GX display.
The Skylla is also connected to the GX display and data appears ax expected on the same GX display.
I would like to configure the Skylla so it follows CVL and CCL values. I have enabled the BMS Present feature (#31) but this lead to the following error after apporximately 10s : "error 67 : BMS connection lost".
I would be very grateful if someone could help suggesting the setup necessary to get the Skylla to honour the CVL and CCL data.
Best regards,
BMSVE.Canip65
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
