xotet avatar image
xotet asked
Lithium battery bank (VE Modules) and Multiplus II
I know this question is bordering not relevant for Victron, but I may not be alone with this issue - and there are so many skilled techies here so I hope you can forgive me.
I just purchased 5x VE modules Samsung SDI 2,08Kwh, modules are configured in 12S cells 42Ah, so the voltage range is between 38,4v-49,2v.
I want to build a bank around 10kWh capacity, so the config 12S5P.
I have a Multiplus II 48/3000 wich I want to use, so the question is the voltage range suitable for the charger section of the Multiplus?
Attached an image of one module
Thanks in advance
Multiplus-IILithium BatteryBMS
xotet avatar image
xotet answered ·
Thanks for your answer,
The individual 42Ah cells are welded together and I suspect messing with that is going to cause more pain and cost more than I would like.
This is why I suggest to give it a try with 12S5P
