John M Brandes avatar image
John M Brandes asked
Do I need to change the dip switches after setting the BMS Assistant?
Just a simple question.
Just installed two multiplus' in parallel single phase. I did successfully install the BMS assistant on the master by switching the dip switches to 1 on and 2 off. All is working. My question is, should the switches be left in that position?
MultiPlus Quattro Inverter ChargerBMS
As long as the VE.bus BMS is connected the DIP switches have to be in that position.
