Hi folks, new here. I am considering a Multiplus II GX, and I need to know whether it can be made to communicate with a Morningstar TS-MPPT-60M charge controller. If anyone has experience with the two.....? TIA. ~TAO
The GX device can only communicate with Victron components.
Well, that isn't completely true. Obviously the GX can talk to other BMS systems for example, using CAN bus.
For example, GX can talk to eg. MG or BYS BMS systems.
There is a solution:
25 People are following this question.
