There is a menu option to Synchronize SOC to 100%. it did work but it hasn't worked since the last update. Are there a set of limiting parameters or conditions?
Thanks TC
Thanks TC
The CCGX does not monitor SOC it just reports or shows you what the system devices are saying. If you are not getting 100% then your system is either not charging or if you have a BMV then it may have lost synchronization.
We wont be able to say conclusively unless we you share more about your system.
Hi, friends!
It seems to me that I have the same problem. Simple th sosv uninterruptible power supply system:
The battery charge does not reach 100% for several days. What is the reason, do you think?
39 People are following this question.
Batteries apparently losing charge on light load
Can Color GX use Wifi for remote VRM comms and wired LAN for direct comms to SolarEdge HD Wave
Quattro based SOC % counts down too slowly but CCGX displays correct AC load wattage
SMA STPTL-30 + data manager M + Victron Quattro = ESS + zero feed-in
Has VRM log been experiencing some sort of issue since this morning?
