Yes I would think they could be different, just means that the internal resistances of the batteries are not the same I would think
you have connected the two in parallel correctly as per the picture Beow ???
Both Pos and Neg Cables should NOT be connected to the same battery but as per the diagram below.
If Not then please reconnect them this way as below and see if that helps with the difference
24 People are following this question.
