cabezonbd avatar image
cabezonbd asked
Cerbo Newbie with a few questions, wifi issues, bluetooth, VRM
Hello, I just received a Cerbo and GX-50 touch screen.
I have VE direct cables from a smart mppt 100/30 and a BVM-712.
I have built a DIY 20 aH LFP battery as a test bed along with a breadboard that holds the smart mppt and BVM712 to learn as much as I can before installing a larger system on a sailboat.
The GX-50 screen indicates correct info via the VE direct connections.
Sorry if these questions are really basic, but I can’t seem to get too far with remote monitoring of the battery system.
1) I am having trouble staying connected to WiFi. It seems it connects then immediately drops out. I have read a little bit about it and want to confirm that a solution involves repositioning of the WiFi antenna?
2) I can connect via Bluetooth but can not seem to get a useable remote screen. Is there possibility that I have a set up screen that I am overlooking?
3) is VRM even possible to get meaningful data from , thinking that the Cerbo is not really connected via Bluetooth or WiFi?
cerbo gx
1. https://community.victronenergy.com/questions/82877/cerbo-gx-wi-fi-issue-when-having-the-gx-touch-conn.html
2. The Cerbo GX Bluetooth is only to setup the LAN/WLAN settings.
https://www.victronenergy.com/media/pg/Cerbo_GX/en/accessing-the-gx-device.html#UUID-58372221-d66e-e9e5-416f-dd3fc2026c6b
3. The Cerbo needs to be connected to the internet (LAN or WLAN) for the VRM Portal.
