Im looking for a device that can manage charge/discharge of 2 lifepo-Batteries with BMS in parallel!
Thx in advance!
Thx in advance!
Are you talking about two Victron Energy LiFePO4 batteries? Then that's no problem.
The batteries are connected to the VE.Bus BMS. I have installed a Victron Energy MultiPlus Compact in my camper. So I can charge the batteries with shore power and also have 110 / 230V available.
The VE.Bus BMS can also control a Victron Energy Smart BatteryProtect to monitor charging and discharging and to switch them off if necessary.
If a Victron Energy Smart Shunt is used, the state of charge of the batteries can be precisely monitored.
The crowning glory would be a Cerbo GX with a connection to VRM (Victron Remote Management). This means that every state, every voltage, every charge etc. can be monitored and alarms can be defined.
Would see it: https://vrm.victronenergy.com/installation/70526/share/c4763105
I hope I was able to answer the question and gave a few suggestions? I am happy to answer any further questions.
24 People are following this question.
