butter-fry avatar image
butter-fry asked
Smart battery Sense ModBus Data stream registers
This seems like a question someone has asked before, but i'm at a loss.
The System is really simple that I'm using
1. 75/15 SmartSolar
2. RPi based VenusOS
3. Smart Battery Sense (new)
TLDR: I just want to know how to pull data via ModBus from the Smart Battery Sense BT module. Not sure why this got moved to 'Modifications'. Seems like a normal product question to me
The problem is simply that I want data to be dumped where I can get it. Everything works fine as far as the VictronConnect app and all. Networked together just fine. I've also MQTT scanned the Venus Mosquito server and can't seem to find any reference to Temperature
My Victron system is dedicated to powering my Smart IoT Hot Tub that I wrote in Home Assistant. I use the ModBus integration so that I can monitor status of the Solar System.
I've tried by trial and error to get the correct Register/Unit/Slave combinations so I can read out the data from the new battery sense module.
Here's what makes sense to me:(Home assistant YAML format, but you'll get the idea if you're unfamiliar)
- platform: modbus
scan_interval: 2
registers:
- name: Battery Temperature
hub: victronsolar
unit_of_measurement: "°c"
precision: 0
data_type: int
scale: 0.1
slave: 239
register: 773
- name: Battery Voltage
hub: victronsolar
unit_of_measurement: "V"
precision: 2
scale: 0.01
slave: 100
register: 771
I've also noticed that the Smart Battery Sense unit doesn't have it's own UnitID. I'm assuming this is because it falls under either system or the network that the MPPT/239 creates. I've been assuming that measurements provided by the SBS unit would fall under 100/239.
Modbus TCPSmart Battery Sensehome assistant
butter-fry answered ·
hah, a year later and I googled the same question only to find my own thread. Anyone ever figure out how to grab the Temps off a Smart Battery Sense module yet?
Modbus TCP Basics
Smart Battery Sense Product Page
Smart Battery Sense Manual
