kmorgan avatar image
kmorgan asked
Victron modbus and hassio help
Hi all, awesome forum, I want to stop discharging battery ess with a Hassio switch, I have looked around and "borrowed" some code to try but seems to work sometimes with the slider but all I want is a switch to turn off ess discharge and if possible start charging(not looked at the last part of charging yet).
If I move the slider to zero it works but if I then move the slider to 100 it does nothing, I have to move the slider to 1 and it some times turns discharge back on..
Does anyone have the skill and acknowledge to help please?
  • Modbus entry
  • - name: "Input Current limit"
  • data_type: uint16
  • unit_of_measurement: “%"
  • slave: 100
  • address: 2702
  • scale: 1.0
  • Config entry
  • input_number:
  • input_current_slider:
  • name: Input Current Limit - Slider
  • min: 0
  • max: 100
  • step: 1.0
  • automation created
  • service: modbus.write_register
  • data:
  • address: 2702
  • unit: 100
  • value: "{ { states('input_number.input_current_slider') | float * 10 }}"
  • hub: victron
Modbus TCPvictronhome assistant
Modbus TCP Basics
