I just added the GX Touch 50 to my Cebro GX. The display is very large on the Touch 50. How do you adjust the resolution so that it fits on the screen?? I can't find anything in the manual.
Thank you.
Thank you.
Ok. I get it now. As I added more items the display adjusted some so that I can see everything.
I was going to ask the same question. I found that if I powered up the Cerbo GX first and later connected the Touch 50, the resolution on the Touch 50 was messed up and the ability to change pages didn't work.
If I have Touch 50 and Cerbo GX already connected when power is turned on then the resolution on the Touch 50 is correct.
The only work around I've found for the wrong resolution is to power down the Cerbo GX and restart while the Touch 50 is connected.
Ok I have the same problem: image is too large for the screen and touch controls are not available. Tried reboots, disconnecting all the cables and re-attaching them one at a time in various combinations. The unit still displays the image too large to view. I upgraded the Cerbo GX to the latest version 2.94 => no change in behaviour. The Touch 50 is basically now useless... any suggestions on how to fix it please?
Unplugging HDMI and the USB, Rebooting 3 times, powering down, reconnecting the Touch 50 and booting fixed the issue for me.
26 People are following this question.
