Jildert avatar image
Jildert asked
Victron Superpack 200 ah
Recently I had installed 3 x 200ah superpack lithium in parallel (series not allowed). In this case max amp draw will be 210amp max continues. ( all cables same length)
In this setup there is a 220Amp Victron battery protect on the main.
I'm wandering about the use of the battery protect, when I consider adding 1 more 200ah to upgrade the max continues draw to 280amps. This battery protect will limit the system.
Does the Powerpack need a battery protect? Since it has an integrated BMS.
Battery ProtectSuperPack
Tom avatar image
Tom answered ·
I have (3) 200Ah SuperPacks with a BatteryProtect 220 installed on my DC current side since I have a 3K Multiplus on my AC side. (I posted a separate question around BMV-712 status of charge.)
It might overkill but I have a frig and computer fans running all the time moving air around to/from my cabinets and garage area under our bed so I didnt want to risk draining the batteries.
Victron BatteryProtect product page
