oleh avatar image
Multiplus Compact - How to realize "AC Output 2" similar to Multiplus
Good day,
I have to install a MultiPlus Compact 12/2000/80-30 to a boat. In difference to the bigger (not compact) Multiplus the compact units have no AC output 2.
This auxilliary output is nice for cutting off the AC power from the hot water boiler when the Multiplus is inverting to reduce the loads on the battery bank.
Has anybody realized a setup like this?
Thanks for hints and suggestions
Greetings from Flensburg, Ole
You have a programmable relay which you can use to activate a bigger contactor.
bjorn-n avatar image
bjorn-n answered ·
I have a MultiPlus-II 48/3000/35-32, the AC output 2 is directly connected to AC input 1 (in my case the grid). To my knowledge, I can't disconnect AC output 2 from AC input 1 by triggering a (built-in) relay.
I would be happen to learn the above statement is wrong though. :-)
At the very first batch of the MP-II the AC OUT 2 was hardwired to the input, there is nothing you can do about it.
You can only use the small programmable relay to switch a larger contactor.
Oh, it seems I have one of the very first Multiplus-II devices which has AC out 2 hard wired to AC in 1.
More info here: https://www.victronenergy.com/upload/documents/MultiPlus-II-to-MultiGrid-and-MultiPlus-comparison-EN.pdf
