Peter avatar image
Peter asked
Do I need a DCDC charger using just a solar MPPT?
4WD canopy and I want to try 100% solar charging without using the car alternator
Battery is a single 110ah lithium battery
Solar panels have yet to be purchased but I want to buy a single fixed panel approx 350W, hardwired, and a 180W blanket. When I run them both, via a switch I expect to run them in series as I understand this is the most efficient option for unbalanced panels.
Is there a 'perfect' sizing for a Victron MPPT and panels?
MPPT SmartSolarchargersolar sizing
6 comments
You cannot combine 2 different spec panels on a single mppt.
Peter avatar image Peter klim8skeptic ♦ commented ·
That's new.... I was told it will be fine in series but in parallel takes the smaller panels values. Is this not the case?
klim8skeptic avatar image klim8skeptic ♦ Peter commented ·
For panels in series, the Imp (working current) needs to be similar.
For panels in parallel, the Vmp (working voltage) needs to be similar.
Makes life easier.... thanks
Zami avatar image Zami klim8skeptic ♦ commented ·
If you put the panels in parallel and the working current is not similar, you can put a Schotty diode on the positive side of the panels and will work. If you don't do that, your panel with smaller amps can blow.
kevgermany avatar image kevgermany ♦♦ Zami commented ·
Please explain in more detail, thanks.
dazey77 avatar image
dazey77 answered ·
Just thought I would chuck in another option thats in the middle (for the DC-DC, not the solar which I think others have covered)
Rather than do DC-DC you can just use the Cyrix-LI to allow from alternator charging in emergencies. If you put a main switch in the line you can run off solar alone most of the time and have a backup. The Cyrix is not expensive or large (but won't work with smart alternators and wont give the perfomance of DC-DC)
spanner avatar image
spanner answered ·
Nope - you can run on solar MPPT alone if you want
michelg avatar image
michelg answered ·
Hi Peter : "Solar panels have yet to be purchased but I want to buy a single fixed panel approx 350kW, hardwired, and a 180kW blanket. When I run them both, via a switch I expect to run them in series as I understand this is the most efficient option for unbalanced panels. "
You mean 350Wp and 180Wp I presume. Consider the voltage of your battery and PVs as these need to be at least 5VDC over the battery voltage, in order to have the mppt working.
In my opinion, you could use the panels in parallel, as in serie being different you will lose part of the power (at least this is what happened in one of my testing setups).
To avoid unexpected surprises, I think you should contact a Victron Dealer, and telll him precisely what you want. Mixing alternator and PVs on the same mppt is not a good idea.
Michel
Peter avatar image Peter commented ·
I don't want to use the alternator. If I do I will get a seperate DCDC charger.... yes you're right about the 350W and 180W
