Dominic avatar image
State of Charge never gets reset - BMV700 with MPPT 75/15 and 110W Solar panel
Hi, Sorry if this is a common question, I'm very new to Solar and trying to learn. I'm very impressed with my Victron gear but there is 1 problem.
I watched the Victron video explaining to change the BMV settings and have done so however the SOC detection still doesn't seem to be working...hope someone can offer some advice.
Setup:
120Ah "Fusion" brand battery
110W Solar Panel
BMV 700
MPPT 75/15
0.8A load
VenusOS on a Pi 3B+ with 2 x USB to VE Direct cables
The battery seems to be charging fine, I can see bulk then absorption then float phases. Unfortunately the SOC never gets reset at all, it just gradually declines until it's zero.
I haven't changed anything on the MPPT, it's by default at Factory default "Gel Victron deep discharge 2".
The BMV I have these settings:
Battery Capacity: 120Ah (I changed this)
Charged voltage: 13.5V (I changed this)
Tail Current: 4% (default)
Charged Detection time: 3m (default)
I set the charged voltage at 13.5V because I can't find the battery stat for this on the manufacturer's details so I looked at the average figure during absorption phase, 13.8. Based on this I set charged voltage at 13.5, 0.3 below absorption rate per video instructions here:
https://www.youtube.com/watch?v=4ReljfO3k6M
I guess I must have misunderstood something, can anyone help?
Thank you.
BMV Battery MonitorSOC
Is the BMV wired correctly?
If the SOC only goes down until 0% even if the MPPT is charging I guess that the (-) of the MPPT is connected directly to the battery instead of to the "load/charger" side of the shunt.
8 comments
Thank you, I agree the cabling doesn't look correct that my friend did. This diagram looks right and will be easier for us to follow. Would you mind checking it is correct please?
All loads and charger negatives must go on the "Loads/Charger" side of the shunt. You watched the video?
Isn't that what's depicted in this diagram?
Sorry I feel like I'm not doing very well here.
Ah you modified it, thanks.
Just so I'm really clear, is it like this?
Looks ok for the charging side.
Dont forget the loads negative wiring also go to that side of the shunt.
My friend is going to re-wire this, final diagram with some load examples....
1, Low current load wifi gear will be attached to the solar charger load ports.
2. High power draw items such as a fridge would be connected to the positive on the battery and the right side of the shunt.
Really appreciate the advice.
Hopefully we've got this right end to end now?
Can confirm cabled up as above and now all working fine, SOC is getting reset and can see the devices in Victron Connect.
Thanks for the help klim8skeptic and Matthias
Dominic answered ·
These are the graphs from VRM portal
Dominic answered ·
Photo of the install
Well, that is a new way to mess up the shunt's wiring. A star for effort.
BMV quick install guide.
Yes, I reviewed the cabling guide, he's cabled it wrong by the looks of it.
This video was also useful
https://youtu.be/MRljOaTdc3s
