David Gould avatar image
David Gould asked
GX reading Grid wrong
OK so not sure how it calculate it but i have the following on my dash. approc 12kw generated , 6.8kw to battery and 11kw to grid which is kinda wrong.
Any ideas why / what. Looking at MQTT the levels look closer to correct, or at least add up better untitled-3.png
Venus GX - VGX
Alexandra avatar image
Alexandra answered ·
@David Gould
It is possible it is a data refresh, sampling or transmit rate of each of the components.
So the synchronisation between each of the widgets is a bit out I would think. Hence also the difference in mqqt and the screen.
I have seen on a few different brands that the delay can be anything up to 10 seconds between load increase or decrease and the figures appearing on the monitoring system.
David Gould answered ·
Thanks for the reply, understand this but it was like it it changing slightly for quite a while
