andreir avatar image
andreir asked
Smartshunt + VE.Direct LoRaWAN are compatible to send SmartShunt data to VRM Portal?
I think to connect a Smartshunt with a VE Direct LoRaWAN, to read remotely the battery State of Charge and other parameters Smartshunt may send to the VRM Portal.
Is this a legitimate, feasible use case supported by Victron? Anybody tested this configuration?
I read VE Direct LoRaWAN manual but I do not see compatibility with the SmartShunt. Thus my questions above.
Below an excerpt form the VE Direct LORaWAN manual:
Product compatibility
This module has one VE.Direct port and is compatible with:
  • All MPPT Solar Charge Controllers which have a VE.Direct Port
  • BMV Battery Monitor 700 series
  • BMV Battery Monitor 712 Smart series
  • Phoenix Inverter VE.Direct models
The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port.
More information is also available on our website: https://www.victronenergy.com/panel-systems-remote-monitoring/ve-direct-lorawan
SmartShuntVE.DirectLoRaWAN
axel-jacobs avatar image axel-jacobs commented ·
Hello, could you tell us if it worked. I intend to do the same? Thanks
I'm not tested it but a SmartShunt is basically a BMV-712 without a display so I guess it should work.
henk-victron avatar image
henk-victron answered ·
Hi
I have just bought a Victron Smatt Shunt and noticed the very low bluethooth signal range. So i want to extend that and if possible by connecting the shunt to the internet.
I already use lorawan in my Camper/RV. It has a TTN gateway and a LTE modem. So i would very much like to connect the Smart shunt by the Victron lorawan module. BUT I read the shunt is not supported though it does have a ve.direct port.
Has anyone tried it as suggested in this tread.?
